AZ2000 HPS - Altazimuthal mount, exclusive 10Micron HPS technology with absolute eencoders and high performances motor drives [10M-2000AZ]
10M-2000AZ
$13,970.00 USD
10Micron: Altazimuthal mount, exclusive 10Micron HPS technology with absolute axis-encoders and high performances motor drives; payload capacity of 50 Kg (110 lbs)
This mount is the last version of the AZ2000, an altazimuth mount based on the mechanics of the GM2000. The AZ2000 HPS is a very versatile research mount, perfect for scientific activities such as satellite tracking, photometric and astrometric measurements, LiDaR laser applications and so on. Due to its altazimuthal design, this special mount isn’t suitable for astrophotography and for most of the amateur activities.
The original AZ2000 was also produced in the special “Antarctica” version, which was able to work at the extreme low temperature of -84°C (-119F). Special mechanical and electronic considerations were necessary in order to design and produce this peculiar mount: from the correct choice of material and sizes to the use of special and very expensive lubricants, wiring and connectors. A special housing was also designed to protect against temperature and ice crystals formation and which needed different levels of seals depending on the effective operational temperature.
About AZ2000 HPS - Altazimuthal mount, exclusive 10Micron HPS technology with absolute eencoders and high performances motor drives [10M-2000AZ]
