Parallax 16.4" OD Tubes (Parks 12.5" Newtonian) [PA-ODT164]
PA-ODT164
$518.80 USD
Parallax Instruments:  Parallax - 16.4" OD Tube Rings (Parks 12.5" Newtonian)
These 16.4" outside diameter split tube rings are made of die-cast aluminum, finished in gloss black paint, and lined with felt. The hinges, no-tool knobs, and hardware are made of stainless steel for long life and easy telescope installation and removal.
About Parallax 16.4" OD Tubes (Parks 12.5" Newtonian) [PA-ODT164]
