Parallax 17.5" OD Tube Rings (Meade 16" SCT) [PA-ODT175]
These 17.5" outside diameter split tube rings are made of die-cast aluminum, finished in gloss black paint, and lined with felt. The hinges, no-tool knobs, and hardware are made of stainless steel for long life and easy telescope installation and removal.
About Parallax 17.5" OD Tube Rings (Meade 16" SCT) [PA-ODT175]
Parallax Instruments: Parallax - 17.5" OD Tube Rings (Meade 16" SCT)
