Parallax 19" OD Tube Rings (Meade DS16A, 16" Starfinder) [PA-ODT19]
These 19" outside diameter split tube rings are made of die-cast aluminum, finished in gloss black paint, and lined with felt. The hinges, no-tool knobs, and hardware are made of stainless steel for long life and easy telescope installation and removal.
About Parallax 19" OD Tube Rings (Meade DS16A, 16" Starfinder) [PA-ODT19]
Parallax Instruments: Parallax - 19" OD Tube Rings (Meade DS16A, 16" Starfinder)
