Parallax 22.4" OD Tube Rings [PA-ODT224]
These 22.4" outside diameter split tube rings are made of die-cast aluminum, finished in gloss black paint, and lined with felt. The hinges, no-tool knobs, and hardware are made of stainless steel for long life and easy telescope installation and removal.
About Parallax 22.4" OD Tube Rings [PA-ODT224]
Parallax Instruments: Parallax - 22.4" OD Tube Rings
