Parallax 26.4" OD Tube Rings [PA-ODT264]
PA-ODT264
$740.34 USD
Parallax Instruments:  Parallax - 26.4" OD Tube Rings
These 26.4" outside diameter split tube rings are made of die-cast aluminum, finished in gloss black paint, and lined with felt. The hinges, no-tool knobs, and hardware are made of stainless steel for long life and easy telescope installation and removal.
About Parallax 26.4" OD Tube Rings [PA-ODT264]
