Parallax 9.5" Rotating Tube Rings (for Parks 8" and Starfinder 8" Newtonians) [PA-RTR95]
The most accurate way to re-position the eyepiece on EQ mounted Newtonians. Rotating tube rings eliminate balance and alignment problems when adjusting eyepiece position for optimal viewing comfort. A must with GoTo systems where alignment is so critical.
These 9.5" rotating tube rings are made of die-cast aluminum finished in gloss black paint. The hinges, no-tool knobs, and hardware are made of stainless steel for long life and easy telescope installation and removal.
About Parallax 9.5" Rotating Tube Rings (for Parks 8" and Starfinder 8" Newtonians) [PA-RTR95]
Parallax Instruments: Parallax - 9.5" Rotating Tube Rings (for Parks 8" and Starfinder 8" Newtonians)
