Parallax 7.64" Rotating Tube Rings (MN-66) [PA-RTR764]
The most accurate way to re-position the eyepiece on EQ mounted Newtonians. Rotating tube rings eliminate balance and alignment problems when adjusting eyepiece position for optimal viewing comfort. A must with GoTo systems where alignment is so critical.
These 7.64" rotating tube rings are made of die-cast aluminum finished in gloss black paint. The hinges, no-tool knobs, and hardware are made of stainless steel for long life and easy telescope installation and removal.
About Parallax 7.64" Rotating Tube Rings (MN-66) [PA-RTR764]
Parallax Instruments: Parallax - 7.64" Rotating Tube Rings (for MN-66)
