FLI 5 Position Color Filter Wheel (for 65mm square filters) [FLI-CFW9-5]
Color Filter Wheels
About FLI 5 Position Color Filter Wheel (for 65mm square filters) [FLI-CFW9-5]
Flight Lakes Instrumentation: 5 Position Color Filter Wheel (for 65mm square filters)
Color Filter Wheels
Five Position Color Filter Wheel
- Number of Filter Wheels: One
- Filter Positions: Five
- Recommended Filter Size (+/- 0.125mm): 65 mm square
- Overall Thickness (less motor): 15.1 mm
- Camera Side Connection: 10-32 Bolt Pattern
- Optical Side Connection: M92-1
- Interface: USB
- Power: 12V
- Weight: 3.2 lbs (1.45 kg)
