FLI 5 Position Color Filter Wheel (for 50mm square filters) [FLI-CFW4-5]
Color Filter Wheels
About FLI 5 Position Color Filter Wheel (for 50mm square filters) [FLI-CFW4-5]
Flight Lakes Instrumentation: 5 Position Color Filter Wheel (for 50mm square filters)
Color Filter Wheels
- Number of Filter Wheels: One
- Filter Positions: Five
- Recommended Filter Size (+/- 0.125mm): 50 mm square
- Overall Thickness (less motor): 19.9 mm
- Camera Side Connection: 2.930" Pocket
- Optical Side Connection: 3.005" - 24 UNS-2B
- Interface: USB
- Power: 12V
- Weight: 2.9 lbs (1.32 kg)
