FLI 20 Position Color Filter Wheel (for 28mm diameter filters) [FLI-CFW3-20-28]
FLI's exclusive multi step Filter Retainer allows the use of ALL square filter thicknesses on the CFW-5-7 and CFW-3-20 Color Filter Wheels.
Color Filter Wheels
About FLI 20 Position Color Filter Wheel (for 28mm diameter filters) [FLI-CFW3-20-28]
Flight Lakes Instrumentation: FLI 20 Position Color Filter Wheel (for 28mm diameter filters)
Color Filter Wheels
- Number of Filter Wheels: One
- Filter Positions: Twenty
- Recommended Filter Size (+/- 0.125mm): 28 mm diameter
- Overall Thickness (less motor): 21.5 mm
- Camera Side Connection: 2.930" Pocket
- Optical Side Connection: 3.005" - 24 UNS-2B
- Interface: USB
- Power: 12V
- Weight: 6.9 lbs (3.14 kg)
