FLI 10 Position Color Filter Wheel (for 50mm square filters) [FLI-CFW3-10]
Color Filter Wheels
About FLI 10 Position Color Filter Wheel (for 50mm square filters) [FLI-CFW3-10]
Flight Lakes Instrumentation: FLI 10 Position Color Filter Wheel (for 50mm square filters)
Color Filter Wheels
- Number of Filter Wheels: One
- Filter Positions: Ten
- Recommended Filter Size (+/- 0.125mm): 50 mm square
- Overall Thickness (less motor): 21.5 mm
- Camera Side Connection: 2.930" Pocket
- Optical Side Connection: 3.005" - 24 UNS-2B
- Interface: USB
- Power: 12V
- Weight: 6.9 lbs (3.14 kg)
