FLI Seven Position Color Filter Wheel (for 2" or 50mm diameter filters) [FLI-CFW2-7]
FLI-CFW2-7
$1,358.85 USD
Flight Lakes Instrumentation: FLI Seven Position Color Filter Wheel (for 2" or 50mm square filters)
FLI's threaded Filter Retainer allows the use of ALL round filter thicknesses on the CFW-2-7 Color Filter Wheel.
Color Filter Wheels
About FLI Seven Position Color Filter Wheel (for 2" or 50mm diameter filters) [FLI-CFW2-7]
Color Filter Wheels
7 Position Color Filter Wheel
  • Number of Filter Wheels:    One
  • Filter Positions:    Seven
  • Recommended Filter Size (+/- 0.125mm):    2 inch or 50 mm diameter
  • Filter Thickness Range:    1.0 - 5.0 mm
  • Overall Thickness (less motor):    20.9 mm
  • Camera Side Connection:    2.930" Pocket
  • Optical Side Connection:    2.005" - 24 UNS-2B
  • Internal Wheel Material:    Aluminum
  • Interface:    USB
  • Power:    12V
  • Weight:    2.9 lbs (1.32 kg)
