FLI 8 Position Color Filter Wheel (for 28mm diameter filters) [FLI-CFW1-8-28]
Color Filter Wheels
About FLI 8 Position Color Filter Wheel (for 28mm diameter filters) [FLI-CFW1-8-28]
Flight Lakes Instrumentation: FLI 8 Position Color Filter Wheel (for 28mm diameter filters)
Color Filter Wheels
- Number of Filter Wheels: One
- Filter Positions: Eight
- Recommended Filter Size (+/- 0.125mm): 28 mm diameter
- Filter Thickness Range: 3.0 - 5.0 mm
- Overall Thickness (less motor): 20.6 mm
- Camera Side Connection: 2.930" Pocket
- Optical Side Connection: 2.005" - 24 UNS-2B
- Internal Wheel Material: Sintra
- Interface: USB
- Power: 12V
- Weight: 1.7 lbs (0.77 kg)
