FLI 5 Position Color Filter Wheel (for 2" or 50mm diameter filters) [FLI-CFW1-5]
FLI-CFW1-5
$946.85 USD
Flight Lakes Instrumentation: FLI 5 Position Color Filter Wheel (for 2" or 50mm diameter filters)
At less than 7/8 of an inch thick, the CFW-1 color filter wheel is designed to closely and rigidly couple to any CCD camera. The homing device of the CFW is highly accurate and repeatable. The recessed opening of the color filter wheel securely clamps to an IMG, MaxCam, or "AD" adapter mounting flange. This setup adds a minimum distance to the light path and avoids the vignetting issues common with other designs.
The T-mount system was introduced by Tamron in 1957 as a universal lens mount for 35mm cameras. The idea was that each lens would have a standard threaded rear flange. A camera specific adapter would then be attached at the point of sale, as needed. This greatly reduced costs since only the T-mount adapters needed to be stocked, rather than different versions of every lens.
With T-mounts readily available for most camera bodies, it was natural for astronomy buffs to settle on it as the standard adapter for 35mm astrophotography. Without this inexpensive and easy to use adapter, astrophotography might have gotten off to a far slower start than it did. On the downside, the T-mount was designed to solve a very specific optical coupling problem in 35mm cameras. Progress in telescope design and CCD array size is revealing the T-mount as a potential bottleneck in the light path.
Color Filter Wheels
About FLI 5 Position Color Filter Wheel (for 2" or 50mm diameter filters) [FLI-CFW1-5]
Color Filter Wheels
  • Number of Filter Wheels:    One
  • Filter Positions:    Five
  • Recommended Filter Size (+/- 0.125mm):    2 inch or 50 mm diameter
  • Filter Thickness Range:    3.0 - 5.0 mm
  • Overall Thickness (less motor):    20.6 mm
  • Camera Side Connection:    2.930" Pocket
  • Optical Side Connection:    2.005" - 24 UNS-2B
  • Internal Wheel Material:    Sintra
  • Interface:    USB
  • Power:    12V
  • Weight:    1.7 lbs (0.77 kg)
