FLI Twenty Position Dual Color Filter Wheel (for 25mm diameter filters) [FLI-CL1-20]
Color Filter Wheels
About FLI Twenty Position Dual Color Filter Wheel (for 25mm diameter filters) [FLI-CL1-20]
Flight Lakes Instrumentation: FLI Twenty Position Dual Color Filter Wheel (for 25mm diameter filters)
Color Filter Wheels
- Number of Filter Wheels: Two
- Filter Positions: Eighteen + Two Open Positions
- Recommended Filter Size (+/- 0.125mm): 25 mm diameter
- Overall Thickness (less motor): 27.9 mm
- Camera Side Connection: 3.43" CL ZTA
- Optical Side Connection: 3.43" CL ZTA
- Interface: USB
- Power: 12V
- Weight: 4.3 lbs (1.95 kg)
