FLI Twenty Position Dual Color Filter Wheel (for 25mm diameter filters) [FLI-CL1-20-25]
FLI-CL1-20-25
$2,594.85 USD
Flight Lakes Instrumentation: FLI Twenty Position Dual Color Filter Wheel (for 25mm diameter filters)
Color Filter Wheels
About FLI Twenty Position Dual Color Filter Wheel (for 25mm diameter filters) [FLI-CL1-20-25]
Color Filter Wheels
  • Number of Filter Wheels:    Two
  • Filter Positions:    Eighteen + Two Open Positions
  • Recommended Filter Size (+/- 0.125mm):    25 mm diameter
  • Filter Thickness Range:    1.0 - 5.0 mm
  • Overall Thickness (less motor):    27.9 mm
  • Camera Side Connection:    3.43" CL ZTA
  • Optical Side Connection:    3.43" CL ZTA
  • Internal Wheel Material:    Aluminum
  • Interface:    USB
  • Power:    12V
  • Weight:    4.3 lbs (1.95 kg)
  • $102.00 USD - [S2] USPS Ground Shipping (7-21 days)
