ProLine PL4240 AM CCD Monochrome Cooled Camera CCD42-40-1-S04 back illuminated Deep Depletion Astro Multilayer-2 NIMO [FLI-PL4240-1-AM]
FLI-PL4240-1-AM
$55,124.85 USD
Flight Lakes Instrumentation: ProLine PL4240 AM CCD Monochrome Cooled Camera CCD42-40-1-S04 back illuminated Deep Depletion Astro Multilayer-2 NIMO - 2048 x 2048 Array with 13.5 µm pixels
This version of the PL4240 uses a back-illuminated sensor on deep depletion silicon, giving improved sensitivity in the near infrared.
Deep depletion silicon has substantially higher dark current than standard silicon.
About ProLine PL4240 AM CCD Monochrome Cooled Camera CCD42-40-1-S04 back illuminated Deep Depletion Astro Multilayer-2 NIMO [FLI-PL4240-1-AM]
PL4240 Astro Multilayer-2 Sensor Specs
  • Sensor:    e2v CCD42-40-1-S04 DD Astro Multilayer-2
  • Pixels:    2048 x 2048
  • Pixel Size:    13.5 μm
  • Sensor Diagonal:    39.1 mm
  • Video Size (inch):    2.4
  • Anti Blooming:    None
  • CCD Type:    Back Illuminated (NIMO)
  • CCD Grades:    Grade 1
PL4240 Astro Multilayer-2 Performance
  • Digitization Speed:    500 kHz and 2 MHz (up to 6 MHz available)
  • Typical System Noise:    10e- RMS @ 500 kHz; 14e- at 2 MHz
  • Typical Dark Current:    15 e-/pixel/sec @ -40ºC
All ProLine Cameras
  • Interface:    USB 2.0>
