ProLine PL4240 DD CCD Monochrome Cooled Camera CCD42-40-1-169 back illuminated Deep Depletion NIMO [FLI-PL4240-DDG1]
FLI-PL4240-DDG1
$46,369.85 USD
Flight Lakes Instrumentation: ProLine PL4240 DD CCD Monochrome Cooled Camera CCD42-40-1-169 back illuminated Deep Depletion NIMO - 2048 x 2048 Array with 13.5 µm pixels
This version of the PL4240 uses a back-illuminated sensor on deep depletion silicon, giving improved sensitivity in the near infrared.
Deep depletion silicon has substantially higher dark current than standard silicon.
About ProLine PL4240 DD CCD Monochrome Cooled Camera CCD42-40-1-169 back illuminated Deep Depletion NIMO [FLI-PL4240-DDG1]
PL4240 Deep Depletion Sensor Specs
  • Sensor:    e2v CCD42-40-1-169 Deep Depletion
  • Pixels:    2048 x 2048
  • Pixel Size:    13.5 μm
  • Sensor Diagonal:    39.1 mm
  • Video Size (inch):    2.4
  • Anti Blooming:    None
  • CCD Type:    Back Illuminated (NIMO)
  • CCD Grades:    Grade 1
PL4240 Deep Depletion Performance
  • Digitization Speed:    500 kHz and 2 MHz (up to 6 MHz available)
  • Typical System Noise:    10e- RMS @ 500 kHz; 14e- at 2 MHz
  • Typical Dark Current:    15 e-/pixel/sec @ -40ºC
All ProLine Cameras
  • Interface:    USB 2.0>
