ProLine PL23042 CCD Monochrome Cooled Camera CCD230-42-1-E10 Back illuminated broadband [FLI-PL23042-1-BB]
FLI-PL23042-1-BB
$42,661.85 USD
Flight Lakes Instrumentation: ProLine PL23042 CCD Monochrome Cooled Camera CCD230-42-1-E10 Back illuminated broadband - 2048 x 2048 Array with 15 µm pixels
About ProLine PL23042 CCD Monochrome Cooled Camera CCD230-42-1-E10 Back illuminated broadband [FLI-PL23042-1-BB]
PL23042 Midband, Broadband Sensor Specs
  • Sensor:    e2v CCD230-42-1-143 (MB) or -E10 (BB)
  • Pixels:    2048 x 2048
  • Pixel Size:    15 μm
  • Full Well Capacity:    150,000 e-
  • Sensor Diagonal:    43.4 mm
  • Video Size (inch):    2.7
  • Anti Blooming:    None
  • CCD Grades:    Grade 1
PL23042 Midband, Broadband Performance
  • Digitization Speed:    500 KHz and 3 MHz
  • Typical System Noise:    13 e- RMS @ 500 KHz; 22 e- at 3 MHz
  • Typical Maximum Cooling:    50ºC Below Ambient
  • Typical Dark Current:    <0.2 e-/pixel/sec @ -30ºC
All ProLine Cameras
  • Interface:    USB 2.0>
