ProLine PL4710 AM CCD Monochrome Cooled Camera CCD47-10-1-197 Back Illuminated Astro Multi-2 deep depletion (NIMO) [FLI-PL4710-1-AM]
FLI-PL4710-1-AM
$16,036.35 USD
Flight Lakes Instrumentation: ProLine PL4710 AM CCD Monochrome Cooled Camera CCD47-10-1-197 Back Illuminated Astro Multi-2 deep depletion (NIMO) - 1024 x 1024 Array with 13 µm pixels
This version of the PL4710 uses a back-illuminated sensor on deep depletion silicon with an enhanced multilayer coating, giving high quantum efficiency across the visible and into the near infrared. Deep depletion silicon has substantially higher dark current than standard silicon.
About ProLine PL4710 AM CCD Monochrome Cooled Camera CCD47-10-1-197 Back Illuminated Astro Multi-2 deep depletion (NIMO) [FLI-PL4710-1-AM]
PL4710 Astro Multilayer-2 Sensor Specs
  • Sensor:    e2v CCD47-10-1-197 DD Astro Multilayer-2
  • Pixels:    1024 x 1024
  • Pixel Size:    13 μm
  • Sensor Diagonal:    18.8 mm
  • Video Size (inch):    1.2
  • Anti Blooming:    None
  • CCD Grades:    Grade 1
PL4710 Astro Multilayer-2 Performance
  • Digitization Speed:    750 kHz, 2 MHz (up to 4 MHz available)
  • Typical System Noise:    10 e- RMS @ 750 kHz; 17e- at 2 MHz
  • Typical Dark Current:    <15 e-/pixel/sec @ -40ºC
All ProLine Cameras
  • Interface:    USB 2.0>
