MicroLine ML4720 Monochrome CCD Cooled Camera CCD47-20-1-170 NIMO back illuminated UV (no shutter) [FLI-ML4720-UV]
FLI-ML4720-UV
$21,134.85 USD
Flight Lakes Instrumentation: MicroLine ML4720 Monochrome CCD Cooled Camera CCD47-20-1-170 NIMO back illuminated UV (no shutter) - 1024 x 1024 Imaging Array 13 μm Pixel Size
The ML4720 uses a back-illuminated frame transfer sensorfrom e2v technologies. Half of the sensor is covered with a metal mask; half is exposed to light.
The exposed side of the sensor is centered in the camera aperture. The image is moved from the exposed side to the masked side in about 10 milliseconds, then read out from the masked side while a new exposure is integrating on the exposed side. (Therefore, frameto-frame timing depends in great part on the digitization speed.)
The default configuration for the camera is two channel readout with software-selectable digitization speeds of 500 kHz and 4 MHz per channel. (Single channel readout is available on request, as are different digitization speeds.)
The UV version of this sensor cannot operate in MPP mode; dark current is much higher than the midband and broadband versions
About MicroLine ML4720 Monochrome CCD Cooled Camera CCD47-20-1-170 NIMO back illuminated UV (no shutter) [FLI-ML4720-UV]
ML4720 UV Sensor Specs
  • Sensor:    E2V CCD47-20
  • Pixels:    1024 x 1024
  • Pixel Size:    13 μm
  • Sensor Diagonal:    18.8
  • Video Size (inch):    1.2
  • Anti Blooming:    None
  • CCD Grades:    Grade 1
ML4720 UV Performance
  • Digitization Speed:    500 kHz and 4MHz per channel (optional single channel)
  • Typical System Noise:    9 e- at 500 kHz; 16 e- at 4 MHz
  • Typical Dark Current:    20 e-/pixel/sec @ -35ºC
  • Available Shutters:    Optional 25 mm
All Microline Cameras
  • Focal Plane to Faceplate:    16 mm (optical)
  • Weight:    3.0 lbs.
  • Interface:    USB 2.0
  • UV sensor is only available as non-IMO (non-MPP) with much higher dark current
