MicroLine ML4720 Monochrome CCD Cooled Camera CCD47-20-1-339 AIMO back illuminated midband (no shutter) [FLI-ML4720-MB]
The ML4720 uses a back-illuminated frame transfer sensorfrom e2v technologies. Half of the sensor is covered with a metal mask; half is exposed to light.
The exposed side of the sensor is centered in the camera aperture. The image is moved from the exposed side to the masked side in about 10 milliseconds, then read out from the masked side while a new exposure is integrating on the exposed side. (Therefore, frameto-frame timing depends in great part on the digitization speed.)
The default configuration for the camera is two channel readout with software-selectable digitization speeds of 500 kHz and 4 MHz per channel. (Single channel readout is available on request, as are different digitization speeds.)
The midband and broadband versions of the sensor are operated in MPP mode (low dark current). The UV version of the sensor is non-MPP
About MicroLine ML4720 Monochrome CCD Cooled Camera CCD47-20-1-339 AIMO back illuminated midband (no shutter) [FLI-ML4720-MB]
Flight Lakes Instrumentation: MicroLine ML4720 Monochrome CCD Cooled Camera CCD47-20-1-339 AIMO back illuminated midband (no shutter) - 1024 x 1024 Imaging Array 13 μm Pixel Size
ML4720 MB Sensor Specs
- Sensor: E2V CCD47-20
- Pixels: 1024 x 1024
- Pixel Size: 13 μm
- Full Well Capacity: 100,000 e-
- Sensor Diagonal: 18.8
- Video Size (inch): 1.2
- Anti Blooming: None
- Color Options: Monochrome
- CCD Type: Back Illuminated
- CCD Grades: Grade 1
ML4720 MB Performance
- Digitization Speed: 500 kHz and 4MHz per channel (optional single channel)
- Typical System Noise: 9 e- at 500 kHz; 16 e- at 4 MHz
- Typical Maximum Cooling: 55ºC Below Ambient
- Typical Dark Current: <0.3 e-/pixel/sec @ -30ºC
- Non linearity: <1%
- Lens Mounts: C-Mount; Optional Nikon F-Mount or Canon EOS mount
- Available Shutters: Optional 25 mm
All Microline Cameras
- Focal Plane to Faceplate: 16 mm (optical)
- Weight: 3.0 lbs.
- Interface: USB 2.0
- Remote Triggering: Standard
- Shutter MTBF: 1,000,000
- Standard configuration has two-channel readout. Single channel optional.
