MicroLine ML4710 Monochrome CCD Cooled Camera CCD47-10-1-373 Back Illuminated UV with 25mm high speed shutter, Fused Silica [FLI-ML4710-UVG1]
About MicroLine ML4710 Monochrome CCD Cooled Camera CCD47-10-1-373 Back Illuminated UV with 25mm high speed shutter, Fused Silica [FLI-ML4710-UVG1]
Flight Lakes Instrumentation: MicroLine ML4710 Monochrome CCD Cooled Camera CCD47-10-1-373 Back Illuminated UV with 25mm high speed shutter, Fused Silica - 1024 x 1024 Imaging Array 13 μm Pixel Size
ML4710 Broadband, Midband, or UV Sensor Specs
- Sensor: E2V CCD47-10-1-371 BB; CCD47-10-1-353 MB; CCD47-10-1-373 UV
- Pixels: 1024 x 1024
- Pixel Size: 13 μm
- Full Well Capacity: 100,000 e-
- Sensor Diagonal: 18.8
- Video Size (inch): 1.2
- Anti Blooming: None
- Color Options: Monochrome
- CCD Type: Back Illuminated
- CCD Grades: Grade 1
ML4710 Broadband, Midband, or UV Performance
- Digitization Speed: 700 kHz and 2MHz (up to 4 MHz available)
- Typical System Noise: 11 e- at 700 kHz; 14 e- at 2 MHz
- Typical Maximum Cooling: 60ºC Below Ambient
- Typical Dark Current: <0.1 e-/pixel/sec @ -40ºC
- Non linearity: <1%
- Lens Mounts: C-Mount; Optional Nikon F-Mount or Canon EOS mount
- Available Shutters: 25 mm
All Microline Cameras
- Focal Plane to Faceplate: 15.7 mm (optical)
- Weight: 3.0 lbs.
- Interface: USB 2.0
- Remote Triggering: Standard
- Shutter MTBF: 1,000,000
