MicroLine ML4710 Monochrome CCD Cooled Camera CCD47-10-1-371 Back Illuminated broadband with 25mm high speed shutter [FLI-ML4710-1-BB]
FLI-ML4710-1-BB
$15,006.35 USD
Flight Lakes Instrumentation: MicroLine ML4710 Monochrome CCD Cooled Camera CCD47-10-1-371 Back Illuminated broadband with 25mm high speed shutter - 1024 x 1024 Imaging Array 13 μm Pixel Size
About MicroLine ML4710 Monochrome CCD Cooled Camera CCD47-10-1-371 Back Illuminated broadband with 25mm high speed shutter [FLI-ML4710-1-BB]
ML4710 Broadband, Midband, or UV Sensor Specs
  • Sensor:    E2V CCD47-10-1-371 BB; CCD47-10-1-353 MB; CCD47-10-1-373 UV
  • Pixels:    1024 x 1024
  • Pixel Size:    13 μm
  • Sensor Diagonal:    18.8
  • Video Size (inch):    1.2
  • Anti Blooming:    None
  • CCD Grades:    Grade 1
ML4710 Broadband, Midband, or UV Performance
  • Digitization Speed:    700 kHz and 2MHz (up to 4 MHz available)
  • Typical System Noise:    11 e- at 700 kHz; 14 e- at 2 MHz
  • Typical Dark Current:    <0.1 e-/pixel/sec @ -40ºC
  • Available Shutters:    25 mm
All Microline Cameras
  • Weight:    3.0 lbs.
  • Interface:    USB 2.0
