MicroLine ML4710 AM Monochrome CCD Cooled Camera CCD47-10-1-197 BI Astro Multi-2 deep depletion (NIMO) with 45mm high speed shutter [FLI-ML4710-AMG1]
This version of the ML4710 uses a back-illuminated sensor on deep depletion silicon with an enhance multilayer coating, giving high quantum efficiency across the visible and into the near infrared. Deep depletion silicon has substantially higher dark current than standard silicon.
About MicroLine ML4710 AM Monochrome CCD Cooled Camera CCD47-10-1-197 BI Astro Multi-2 deep depletion (NIMO) with 45mm high speed shutter [FLI-ML4710-AMG1]
Flight Lakes Instrumentation: MicroLine ML4710 AM Monochrome CCD Cooled Camera CCD47-10-1-197 BI Astro Multi-2 deep depletion (NIMO) with 45mm high speed shutter - 1024 x 1024 Imaging Array 13 μm Pixel Size
ML4710 Astro Multilayer-2 Sensor Specs
- Sensor: E2V CCD47-10-1-197 (Astro Multilayer-2)
- Pixels: 1024 x 1024
- Pixel Size: 13 μm
- Full Well Capacity: 100,000 e-
- Sensor Diagonal: 18.8
- Video Size (inch): 1.2
- Anti Blooming: None
- Color Options: Monochrome
- CCD Type: Back Illuminated
- CCD Grades: Grade 1
ML4710 Astro Multilayer-2 Performance
- Digitization Speed: 700 kHz and 2MHz (up to 4 MHz available)
- Typical System Noise: 11 e- at 700 kHz; 14 e- at 2 MHz
- Typical Maximum Cooling: 60ºC Below Ambient
- Typical Dark Current: 15 e-/pixel/sec @ -40ºC
- Non linearity: <1%
- Lens Mounts: C-Mount; Optional Nikon F-Mount, Canon EOS mount, or Micro 4/3 mount
- Available Shutters: 25 mm
All Microline Cameras
- Focal Plane to Faceplate: 16 mm (optical)
- Weight: 3.0 lbs.
- Interface: USB 2.0
- Remote Triggering: Standard
- Shutter MTBF: 1,000,000
- AM sensor is only available as non-IMO (non-MPP) with much higher dark current
