MicroLine ML4240 Monochrome CCD Cooled Camera CCD42-40-1-075 back illuminated UV (NIMO) with 45mm high speed shutter, Fused Silica [FLI-ML4240-UVG1]
FLI-ML4240-UVG1
$38,644.85 USD
Flight Lakes Instrumentation: MicroLine ML4240 Monochrome CCD Cooled Camera CCD42-40-1-075 back illuminated UV (NIMO) with 45mm high speed shutter, Fused Silica - 2048 x 2048 Imaging Array 13.5 μm Pixel Size
MicroLine cameras can achieve up to 60°C below ambient cooling without water assist. Simply set the MicroLine cooling where you want it and the camera will do the rest, quickly and without worries.
About MicroLine ML4240 Monochrome CCD Cooled Camera CCD42-40-1-075 back illuminated UV (NIMO) with 45mm high speed shutter, Fused Silica [FLI-ML4240-UVG1]
ML4240 UV Sensor Specs
  • Sensor:    E2V CCD42-40-1-075 UV
  • Pixels:    2048 x 2048
  • Pixel Size:    13.5 μm
  • Sensor Diagonal:    39.1
  • Video Size (inch):    2.4
  • Anti Blooming:    None
  • CCD Grades:    Grade 1
ML4240 UV Performance
  • Digitization Speed:    500 kHz and 2MHz (up to 2 channels at 3 MHz each)
  • Typical System Noise:    10 e- at 500 kHz; 14 e- at 2 MHz (23e- at 3 MHz)
  • Typical Dark Current:    20 e-/pixel/sec @ -35ºC (UV)
  • Available Shutters:    45 mm
All Microline Cameras
  • Focal Plane to Faceplate:    16 mm (optical)
  • Weight:    3.0 lbs.
  • Interface:    USB 2.0
  • The UV version of this sensor is only available as non-IMO (non-MPP) with increased dark current.
