MicroLine ML4240 Monochrome CCD Cooled Camera CCD42-40-1-368 back illuminated midband with 45mm high speed shutter [FLI-ML4240-MBG1]
FLI-ML4240-MBG1
$38,644.85 USD
Flight Lakes Instrumentation: MicroLine ML4240 Monochrome CCD Cooled Camera CCD42-40-1-368 back illuminated midband with 45mm high speed shutter - 2048 x 2048 Imaging Array 13.5 μm Pixel Size
MicroLine cameras can achieve up to 60°C below ambient cooling without water assist. Simply set the MicroLine cooling where you want it and the camera will do the rest, quickly and without worries.
About MicroLine ML4240 Monochrome CCD Cooled Camera CCD42-40-1-368 back illuminated midband with 45mm high speed shutter [FLI-ML4240-MBG1]
ML4240 Midband or Broadband Sensor Specs
  • Sensor:    E2V CCD42-40-1-368 MB or -371 BB
  • Pixels:    2048 x 2048
  • Pixel Size:    13.5 μm
  • Sensor Diagonal:    39.1
  • Video Size (inch):    2.4
  • Anti Blooming:    None
  • CCD Grades:    Grade 1
ML4240 Midband or Broadband Performance
  • Digitization Speed:    500 kHz and 2MHz (up to 2 channels at 3 MHz each)
  • Typical System Noise:    9 e- at 500 kHz; 14 e- at 2 MHz (23e- at 3 MHz)
  • Typical Dark Current:    <0.2 e-/pixel/sec @ -30ºC
  • Available Shutters:    45 mm
All Microline Cameras
  • Focal Plane to Faceplate:    16 mm (optical)
  • Weight:    3.0 lbs.
  • Interface:    USB 2.0
