MicroLine ML4240 AM Monochrome CCD Cooled Camera CCD42-40-1-S04 back illuminated NIMO Astro M2 with 45mm high speed shutter [FLI-ML4240-1-AM]
FLI-ML4240-1-AM
$54,094.85 USD
Flight Lakes Instrumentation: MicroLine ML4240 AM Monochrome CCD Cooled Camera CCD42-40-1-S04 back illuminated NIMO Astro M2 with 45mm high speed shutter - 2048 x 2048 Imaging Array 13.5 μm Pixel Size
This version of the ML4240 uses a back-illuminated sensor on deep depletion silicon with an enhanced multilayer coating, giving high quantum efficiency across the visible and into the near infrared. Deep depletion silicon has substantially higher dark current than standard silicon.
About MicroLine ML4240 AM Monochrome CCD Cooled Camera CCD42-40-1-S04 back illuminated NIMO Astro M2 with 45mm high speed shutter [FLI-ML4240-1-AM]
ML4240 Astro Multilayer-2 Sensor Specs
  • Sensor:    E2V CCD42-40-1-S04 DD Astro Multilayer-2
  • Pixels:    2048 x 2048
  • Pixel Size:    13.5 μm
  • Sensor Diagonal:    39.1
  • Video Size (inch):    2.4
  • Anti Blooming:    None
  • CCD Grades:    Grade 1
ML4240 Astro Multilayer-2 Performance
  • Digitization Speed:    500 kHz and 2MHz (up to 2 channels at 3 MHz each)
  • Typical System Noise:    9 e- at 500 kHz; 14 e- at 2 MHz (23e- at 3 MHz)
  • Typical Dark Current:    15 e-/pixel/sec @ -40ºC
  • Available Shutters:    45 mm
All Microline Cameras
  • Focal Plane to Faceplate:    16 mm (optical)
  • Weight:    3.0 lbs.
  • Interface:    USB 2.0
  • The AM version of this sensor is only available as non-IMO (non-MPP) with increased dark current
