MicroLine ML4210 Monochrome CCD Cooled Camera CCD42-10-1-319 back illuminated enhanced broadband with 45mm high speed shutter [FLI-ML4210-EBBG1]
FLI-ML4210-EBBG1
$19,074.85 USD
Flight Lakes Instrumentation: MicroLine ML4210 Monochrome CCD Cooled Camera CCD42-10-1-319 back illuminated enhanced broadband with 45mm high speed shutter - 2048 x 512 Imaging Array 13.5 μm Pixel Size
MicroLine download speeds are fast yet maintain the 16-bit resolution necessary to produce high quality images. The MicroLine ML4210 camera can achieve up to 55°C below ambient cooling without water assist. Simply set the MicroLine cooling where you want it and the camera will do the rest, quickly and without worries.
About MicroLine ML4210 Monochrome CCD Cooled Camera CCD42-10-1-319 back illuminated enhanced broadband with 45mm high speed shutter [FLI-ML4210-EBBG1]
ML4210 Sensor Specs
  • Sensor:    e2v CCD42-10-1-970 (MB); -319 (BB); -313 (UV)
  • Pixels:    2048 x 512
  • Pixel Size:    13.5 μm
  • Sensor Diagonal:    28.5
  • Video Size (inch):    1.8
  • Anti Blooming:    None
  • CCD Grades:    Grade 1
ML4210 Performance
  • Digitization Speed:    500 kHz and 2MHz
  • Typical System Noise:    10 e- at 500 kHz; 15 e- at 2 MHz
  • Typical Dark Current:    <0.1 e-/pixel/sec @ -35ºC
  • Available Shutters:    Optional 45 mm
All Microline Cameras
  • Weight:    3.0 lbs.
  • Interface:    USB 2.0
