MicroLine ML23042 Monochrome CCD Cooled Camera CCD230-42-1-143 back illuminated midband with shutter [FLI-ML23042-1-MBG1]
FLI-ML23042-1-MBG1
$41,116.85 USD
Flight Lakes Instrumentation: MicroLine ML23042 Monochrome CCD Cooled Camera CCD230-42-1-143 back illuminated midband with shutter - 2048 x 2048 Imaging Array 15 μm Pixel Size
MicroLine download speeds are fast yet maintain the 16-bit resolution necessary to produce high quality images. The MicroLine ML23042 camera can achieve up to 50°C below ambient cooling without water assist. Simply set the MicroLine cooling where you want it and the camera will do the rest, quickly and without worries.
About MicroLine ML23042 Monochrome CCD Cooled Camera CCD230-42-1-143 back illuminated midband with shutter [FLI-ML23042-1-MBG1]
ML23042 Midband, Broadband Sensor Specs
  • Sensor:    E2V CCD230-42
  • Pixels:    2048 x 2048
  • Pixel Size:    15 μm
  • Full Well Capacity:    150,000 e-
  • Sensor Diagonal:    43.4
  • Video Size (inch):    2.7
  • Anti Blooming:    None
  • CCD Grades:    Grade 1
ML23042 Midband, Broadband Performance
  • Digitization Speed:    750 KHz and 2 MHz
  • Typical System Noise:    16 e- RMS @ 750 KHz; 24 e- at 2 MHz
  • Typical Maximum Cooling:    50ºC Below Ambient (Air Cooled)
  • Typical Dark Current:    <0.2 e-/pixel/sec @ -30ºC
All Microline Cameras
  • Focal Plane to Faceplate:    20.9 mm (optical)
  • Weight:    4.5 lbs. (2.0 kg.)
  • Interface:    USB 2.0
