MicroLine ML1109 Monochrome CCD Cooled Camera Hamamatsu S10140-1109 (no shutter) [FLI-ML1109]
FLI-ML1109
$12,791.85 USD
Flight Lakes Instrumentation: MicroLine ML1109 Monochrome CCD Cooled Camera Hamamatsu S10140-1109 (no shutter) - 2048 x 506 Imaging Array 12 μm Pixel Size
About MicroLine ML1109 Monochrome CCD Cooled Camera Hamamatsu S10140-1109 (no shutter) [FLI-ML1109]
ML1109 Spectroscopy Sensor Specs
  • Sensor:    Hamamatsu S10140-1109
  • Pixels:    2048 x 506
  • Pixel Size:    12 μm
  • Full Well Capacity:    75,000 e-
  • Sensor Diagonal:    24.7
  • Video Size (inch):    1.6
  • Anti Blooming:    None
  • CCD Grades:    Standard
ML1109 Spectroscopy Performance
  • Digitization Speed:    115 and 460 kHz
  • Typical System Noise:    11 e- RMS @ 115 kHz
  • Typical Dark Current:    1.5 e-/pixel/sec @ -40ºC
  • Available Shutters:    Optional 45 mm
All Microline Cameras
  • Focal Plane to Faceplate:    16 mm (optical)
  • Weight:    3.0 lbs.
  • Interface:    USB 2.0
  • Shutter MTBF:    NA
