MicroLine MLX814 Monochrome CCD Cooled Camera Sony ICX814 (no shutter) [FLI-MLX814]
FLI-MLX814
$5,478.85 USD
Flight Lakes Instrumentation: MicroLine MLX814 Monochrome CCD Cooled Camera Sony ICX814 (no shutter) - 3380 x 2704 Imaging Array 3.69 μm Pixel Size
High quantum efficiency, exceptionally low read noise, and high spatial resolution make the MLx814 an ideal candidate for low light applications such as fluorescence.
· Standard configuration: single channel with software selectable download speeds: 1.5 MHz for exceptionally low noise, and 12 MHz
· Optional configuration: 2 channels at 12 MHz each
· Optional liquid circulation for cooling
· Standard C-mount thread or optional FLI dovetail for usewith a variety of adapters, such as Nikon F-mount or Canon EOS
About MicroLine MLX814 Monochrome CCD Cooled Camera Sony ICX814 (no shutter) [FLI-MLX814]
MLx814 Sensor Specs
  • Sensor:    Sony ICX814AL
  • Pixels:    3380 x 2704
  • Pixel Size:    3.69 μm
  • Full Well Capacity:    15,000 e-
  • Sensor Diagonal:    16
  • Video Size (inch):    1.0
  • Anti Blooming:    Yes
  • CCD Grades:    Standard
MLx814 Performance
  • Digitization Speed:    1.5 and 12 MHz (optional dual channel)
  • Typical System Noise:    2e- RMS @ 1.5 MHz; 4e- @ 12 MHz
  • Typical Dark Current:    0.001 e-/pixel/sec @ -30ºC
  • Available Shutters:    Sensor has electronic shutter. Optional 25 mm
All MicroLine Cameras
  • Weight:    2.8 lbs
  • Interface:    USB 2.0
  • Shutter MTBF:    NA
