MicroLine MLX695 Monochrome CCD Cooled Camera Sony ICX695 (no shutter) [FLI-MLX695]
FLI-MLX695
$5,890.85 USD
Flight Lakes Instrumentation: MicroLine MLX695 Monochrome CCD Cooled Camera Sony ICX695 (no shutter) - 2750 x 2200 Imaging Array 4.54 μm Pixel Size
High quantum efficiency and exceptionally low read noise give the MLx695 sensitivity down to microlux from visible to the near infrared.
High spatial resolution makes the MLx695 ideal for low light applications such as fluorescence.
Standard configuration: single channel with softwareselectable
download speeds: 1.7 MHz for exceptionally low noise, and 12 MHz (about 1 frame per second).
Optional configuration: 2 channels at 12 MHz each (about 2 frames per second)
Air cooling to 60°C below ambient. Optional liquid circulation for cooling to 80°C below ambient.
Standard C-mount thread or optional FLI dovetail for use with a variety of adapters, such as Nikon F-mount or Canon EOS
About MicroLine MLX695 Monochrome CCD Cooled Camera Sony ICX695 (no shutter) [FLI-MLX695]
MLx695 Sensor Specs
  • Sensor:    Sony ICX695AL
  • Pixels:    2750 x 2200
  • Pixel Size:    4.54 μm
  • Full Well Capacity:    17,000 e-
  • Sensor Diagonal:    16
  • Video Size (inch):    1.0
  • Anti Blooming:    Yes
  • CCD Grades:    Standard
MLx695 Performance
  • Digitization Speed:    1.7 and 12 MHz (optional dual channel)
  • Typical System Noise:    3e- RMS @ 1.7 MHz; 5.1e- @ 12 MHz
  • Typical Dark Current:    0.0007 e-/pixel/sec @ -30ºC
  • Available Shutters:    Sensor has electronic shutter. Optional 25 mm
All MicroLine Cameras
  • Weight:    2.8 lbs
  • Interface:    USB 2.0
  • Shutter MTBF:    NA
