MicroLine MLX694 Monochrome CCD Cooled Camera Sony ICX694 (no shutter) [FLI-MLX694]
FLI-MLX694
$5,890.85 USD
Flight Lakes Instrumentation: MicroLine MLX694 Monochrome CCD Cooled Camera Sony ICX694 (no shutter) - 2750 x 2200 Imaging Array 4.54 μm Pixel Size
High quantum efficiency, exceptionally low read noise, and high spatial resolution make the MLx694 an ideal candidate for low light applications such as fluorescence.
· Standard configuration: single channel with software selectable download speeds: 1.5 MHz for exceptionally low noise, and 12 MHz
· Optional configuration: 2 channels at 12 MHz each
· Optional liquid circulation for cooling
· Standard C-mount thread or optional FLI dovetail for use with a variety of adapters, such as Nikon F-mount or Canon EOS
About MicroLine MLX694 Monochrome CCD Cooled Camera Sony ICX694 (no shutter) [FLI-MLX694]
MLx694 Sensor Specs
  • Sensor:    Sony ICX694AL
  • Pixels:    2750 x 2200
  • Pixel Size:    4.54 μm
  • Full Well Capacity:    18,000 e-
  • Sensor Diagonal:    16
  • Video Size (inch):    1.0
  • Anti Blooming:    Yes
  • CCD Grades:    Standard
MLx694 Performance
  • Digitization Speed:    1.5 and 12 MHz (optional dual channel)
  • Typical System Noise:    3e- RMS @ 1.5 MHz; 5.5e- @ 12 MHz
  • Typical Dark Current:    0.001 e-/pixel/sec @ -35ºC
  • Available Shutters:    Sensor has electronic shutter. Optional 25 mm
All MicroLine Cameras
  • Weight:    2.8 lbs
  • Interface:    USB 2.0
  • Shutter MTBF:    NA
