MicroLine MLX674 Monochrome CCD Cooled Camera Sony ICX674 (no shutter) [FLI-MLX674]
FLI-MLX674
$4,757.85 USD
Flight Lakes Instrumentation: MicroLine MLX674 Monochrome CCD Cooled Camera Sony ICX674 (no shutter) - 1940 x 1460 Imaging Array 4.54 μm Pixel Size
High quantum efficiency, exceptionally low read noise, and high spatial resolution make the MLx674 an ideal candidate for low light applications such as fluorescence.
· Standard configuration: single channel with software selectable download speeds: 1.5 MHz for exceptionally low noise, and 12 MHz
· Optional configuration: 2 channels at 12 MHz each
· Optional liquid circulation for cooling
· Standard C-mount thread or optional FLI dovetail for use with a variety of adapters, such as Nikon F-mount or Canon EOS
About MicroLine MLX674 Monochrome CCD Cooled Camera Sony ICX674 (no shutter) [FLI-MLX674]
MLx674 Sensor Specs
  • Sensor:    Sony ICX674AL
  • Pixels:    1940 x 1460
  • Pixel Size:    4.54 μm
  • Full Well Capacity:    18,000 e-
  • Sensor Diagonal:    11
  • Video Size (inch):    0.7
  • Anti Blooming:    Yes
  • CCD Grades:    Standard
MLx674 Performance
  • Digitization Speed:    1.5 and 12 MHz (optional dual channel)
  • Typical System Noise:    3e- RMS @ 1.5 MHz; 5.5e- @ 12 MHz
  • Typical Dark Current:    0.001 e-/pixel/sec @ -35ºC
  • Available Shutters:    Sensor has electronic shutter. Optional 25 mm
All MicroLine Cameras
  • Weight:    2.8 lbs
  • Interface:    USB 2.0
  • Shutter MTBF:    NA
