MicroLine ML8670 Monochrome CCD Cooled Camera KAI-08670 Grade 1 [FLI-ML8670-1]
FLI-ML8670-1
$10,319.85 USD
Flight Lakes Instrumentation: MicroLine ML8670 Monochrome CCD Cooled Camera KAI-08670 Grade 1  - 3600 x 2400 Imaging Array 7.4 μm Pixel Size
3.7 x 3.7 x 4.8 inches the MicroLine is a small camera with big camera capabilities. Each component of the MicroLine camera is designed and manufactured for a long life in the most demanding conditions.
About MicroLine ML8670 Monochrome CCD Cooled Camera KAI-08670 Grade 1 [FLI-ML8670-1]
ML8670 Sensor Specs
  • Sensor:    ON Semi KAI-08670
  • Pixels:    3600 x 2400
  • Pixel Size:    7.4 μm
  • Full Well Capacity:    44,000 e-
  • Sensor Diagonal:    31.9 mm
  • Video Size (inch):    2.0
  • Anti Blooming:    1000x
  • CCD Grades:    1 or 2
ML8670 Performance
  • Typical System Noise:    8e- RMS @ 4 MHz; 11e- RMS @ 12 MHz
  • Typical Dark Current:    <0.005 electrons/pixel/sec @ -25ºC
  • Available Shutters:    Sensor has electronic shutter. Optional 45 mm
All MicroLine Cameras
  • Weight:    2.8 lbs (1.3 kg)
  • Interface:    USB 2.0
