ProLine PL4710-DD CCD Monochrome Cooled Camera CCD47-10-1-109 deep depletion [FLI-PL4710-DD]
FLI-PL4710-DD
$17,838.85 USD
Flight Lakes Instrumentation: ProLine PL4710-DD CCD Monochrome Cooled Camera CCD47-10-1-109 deep depletion- 1024 x 1024 Array with 13 µm pixels
About ProLine PL4710-DD CCD Monochrome Cooled Camera CCD47-10-1-109 deep depletion [FLI-PL4710-DD]
PL4710 Deep Depletion Sensor Specs
  • Sensor:    e2v CCD47-10-1-109 Deep Depletion
  • Pixels:    1024 x 1024
  • Pixel Size:    13 μm
  • Sensor Diagonal:    18.8 mm
  • Video Size (inch):    1.2
  • Anti Blooming:    None
  • CCD Grades:    Grade 1
PL4710 Deep Depletion Performance
  • Digitization Speed:    750 kHz, 2 MHz (up to 4 MHz available)
  • Typical System Noise:    10 e- RMS @ 750 kHz
  • Typical Maximum Cooling:    65ºC Below Ambient
  • Typical Dark Current:    <15 e-/pixel/sec @ -40ºC
All ProLine Cameras
  • Interface:    USB 2.0>
