ProLine PL4710-BB CCD Monochrome Cooled Camera CCD47-10-1-371 broadband [FLI-PL4710-BB]
FLI-PL4710-BB
$16,036.35 USD
Flight Lakes Instrumentation: ProLine PL4710-BB CCD Monochrome Cooled Camera CCD47-10-1-371 broadband - 1024 x 1024 Array with 13 µm pixels
About ProLine PL4710-BB CCD Monochrome Cooled Camera CCD47-10-1-371 broadband [FLI-PL4710-BB]
PL4710 Broadband, Midband, or UV Sensor Specs
  • Sensor:    e2v CCD47-10-1-353(MB), -371(BB), -373(UV)
  • Pixels:    1024 x 1024
  • Pixel Size:    13 μm
  • Sensor Diagonal:    18.8 mm
  • Video Size (inch):    1.2
  • Anti Blooming:    None
  • CCD Grades:    Grade 1
PL4710 Broadband, Midband, or UV Performance
  • Digitization Speed:    700 kHz, 2 MHz (up to 4 MHz available)
  • Typical Maximum Cooling:    65ºC Below Ambient
  • Typical Dark Current:    <0.05 e-/pixel/sec @ -45ºC
All ProLine Cameras
  • Interface:    USB 2.0>
