ProLine PL4720-UV CCD Monochrome Cooled Camera CCD47-20-1-170 Back Illuminated NIMO UV coating (no shutter) [FLI-PL4720-UV]
FLI-PL4720-UV
$23,457.50 USD
Flight Lakes Instrumentation: ProLine PL4720-UV CCD Monochrome Cooled Camera CCD47-20-1-170 Back Illuminated NIMO UV coating (no shutter) - 1024 x 1024 Array with 13 µm pixels
The PL4720 UV uses a back-illuminated frame transfer sensor from e2v technologies.
Half of the sensor is covered with a metal mask; half is exposed to light.
The exposed side of the sensor is centered in the camera aperture.
The image is moved from the exposed side to the masked side in about 10 milliseconds, then read out from the masked side while a new exposure is integrating on the exposed side. (Therefore, frame-to-frame timing depends in great part on the digitization speed.) The default configuration for the camera is two channel readout with software-selectable digitization speeds of 500 kHz and 2 MHz per channel. (Single channel readout is available on request, as are different digitization speeds.)
About ProLine PL4720-UV CCD Monochrome Cooled Camera CCD47-20-1-170 Back Illuminated NIMO UV coating (no shutter) [FLI-PL4720-UV]
PL4720 UV Sensor Specs
  • Sensor:    e2v CCD47-20-1-170
  • Pixels:    1024 x 1024
  • Pixel Size:    13 μm
  • Sensor Diagonal:    18.8 mm
  • Video Size (inch):    1.2
  • Anti Blooming:    None
  • CCD Type:    Back Illuminated Frame Transfer
  • CCD Grades:    Grade 1
PL4720 UV Performance
  • Digitization Speed:    500 kHz and 2 MHz
  • Typical System Noise:    10 e- RMS @ 500 kHz and 13 e- at 2 MHz
  • Typical Dark Current:    20 e-/pixel/sec @ -30ºC
  • Available Shutters:    Optional 65 mm
All ProLine Cameras
  • Interface:    USB 2.0>
  • Shutter MTBF:
