ProLine PL16000 CCD Color Cooled Camera with KAI-16000M Grade 1 Sensor (No shutter) [FLI-PL16000-C1]
FLI-PL16000-C1
$11,143.85 USD
Flight Lakes Instrumentation: ProLine PL16000 CCD Color Cooled Camera with KAI-16000M Grade 1 Sensor (No shutter)  -  4872 x 3248 Array with 7.4 µm pixels
ProLine frame quality is second to none thanks to careful design,
implementation,and setup.
All cameras are assembled in our clean room under exacting conditions andmust pass a battery of tests before being shipped.
About ProLine PL16000 CCD Color Cooled Camera with KAI-16000M Grade 1 Sensor (No shutter) [FLI-PL16000-C1]
PL16000 Sensor Specs
  • Sensor:    ON Semi KAI-16000
  • Pixels:    4872 x 3248
  • Pixel Size:    7.4 μm
  • Full Well Capacity:    30,000 e-
  • Sensor Diagonal:    43.3 mm
  • Video Size (inch):    2.7
  • Anti Blooming:    100x
  • CCD Grades:    1, 2
PL16000 Performance
  • Digitization Speed:    12 MHz
  • Typical System Noise:    8e- @ 4 MHz; 11e- @ 12 MHz
  • Typical Dark Current :    <.001 e-/pixel/sec @ -35ºC
All ProLine Cameras
  • Interface:    USB 2.0
