Hyperion HP4710-1-BB Monochrome CCD Cooled Camera CCD47-10-1-371 broadband with 25mm shutter [FLI-HP4710-1-BB]
FLI-HP4710-1-BB
$15,315.35 USD
Flight Lakes Instrumentation: Hyperion HP4710-1-BB Monochrome CCD Cooled Camera CCD47-10-1-371 broadband with 25mm shutter - 1024 x 1024 Imaging Array 13 μm Pixel Size
Each component of the Hyperion camera is designed and manufactured for a long life in the most demanding conditions. Hyperion download speeds are fast yet maintain the 16-bit resolution necessary to produce high quality images. Hyperion cameras can cool to as much as 60°C below ambientwithout water assist. Simply set the Hyperion cooling where you want it and the camera will do the rest, quickly and without worries.
About Hyperion HP4710-1-BB Monochrome CCD Cooled Camera CCD47-10-1-371 broadband with 25mm shutter [FLI-HP4710-1-BB]
HP4710 Broadband Sensor Specs
  • Sensor:    E2V CCD47-10-1-371
  • Pixels:    1024 x 1024
  • Pixel Size:    13 μm
  • Sensor Diagonal:    18.8 mm
  • Video Size (inch):    1.2
  • Anti Blooming:    None
  • CCD Grades:    Standard
HP4710 Broadband Performance
  • Digitization Speed:    700 kHz, 2 MHz (up to 4 MHz available)
  • Typical Dark Current:    <0.1 e-/pixel/sec @ -40ºC
  • CCD to Flange Distance:
  • Available Shutters:    25mm or 45mm
All Hyperion Cameras
  • Housing Dimensions:    4.0 x 6.75 x 3.35 (101.6 x 171.5 x 85.1)
  • Weight:    4.0 lbs. (Liquid Cooled - 2.8 lbs.)
  • Interface:    USB 2.0>
