Hyperion HP8051 Color CCD Cooled Camera KAI-08051 (no shutter) [FLI-HP8051-C]
FLI-HP8051-C
$5,478.85 USD
Flight Lakes Instrumentation: Hyperion HP8051 Color CCD Cooled Camera KAI-08051 (no shutter) - 3296 x 2472 Imaging Array 5.5 μm Pixel Size
Each component of the Hyperion camera is designed and manufactured for a long life in the most demanding conditions. Hyperion download speeds are fast yet maintain the 16-bit resolutionnecessary to produce high quality images. Hyperion cameras can cool to as much as 60°C below ambientwithout water assist. Simply set the Hyperion cooling where you want it and the camera will do the rest, quickly and without worries.
About Hyperion HP8051 Color CCD Cooled Camera KAI-08051 (no shutter) [FLI-HP8051-C]
HP8051 Sensor Specs
  • Sensor:    ON Semi KAI-08051
  • Pixels:    3296 x 2472
  • Pixel Size:    5.5 μm
  • Sensor Diagonal:    22.7 mm
  • Video Size (inch):    1.4
  • Anti Blooming:    300X
  • CCD Grades:    Standard
HP8051 Performance
  • Digitization Speed:    1.5 MHz and 12 MHz (Optional two channels at 10 MHz each)
  • Typical System Noise:    3.5 e- RMS @ 1.5 MHz; 6 e- at 12 MHz
  • Typical Dark Current:    <0.001 e-/pixel/sec @ -30ºC
  • CCD to Flange Distance:    17 mm (optical)
  • Lens Mounts:    Optional Nikon F-Mount or Canon EOS
  • Available Shutters:    Sensor has an electronic shutter. Optional 25 or 45mm.
All Hyperion Cameras
  • Housing Dimensions:    6.75 x 4.0 x 3.35 (171.5 x 101.6 x 85.1mm)
  • Weight:    3.4 lbs. (1.5 kg)
  • Interface:    USB 2.0>
