Hyperion HPx695 Monochrome CCD Cooled Camera Sony ICX695ALG monochrome sensor (no shutter) [FLI-HPX695]
FLI-HPX695
$6,199.85 USD
Flight Lakes Instrumentation: Hyperion HPx695 Monochrome CCD Cooled Camera Sony ICX695ALG monochrome sensor (no shutter) - 2750 x 2200 Imaging Array 4.54 μm Pixel Size
Each component of the Hyperion camera is designed and manufactured for a long life in the most demanding conditions. Hyperion download speeds are fast yet maintain the 16-bit resolutionnecessary to produce high quality images. Hyperion cameras can cool to as much as 60°C below ambientwithout water assist. Simply set the Hyperion cooling where you want it and the camera will do the rest, quickly and without worries.
About Hyperion HPx695 Monochrome CCD Cooled Camera Sony ICX695ALG monochrome sensor (no shutter) [FLI-HPX695]
HPx695 Sensor Specs
  • Sensor:    Sony ICX695
  • Pixels:    2750 x 2200
  • Pixel Size:    4.54 μm
  • Sensor Diagonal:    16 mm
  • Video Size (inch):    1.0
  • Anti Blooming:    Yes
  • CCD Grades:    Standard
HPx695 Performance
  • Digitization Speed:    1.5 MHz and 12 MHz (Optional two channels at 12 MHz each)
  • Typical System Noise:    3 e- RMS @ 1.5 MHz; 5.5 e- at 12 MHz
  • Typical Dark Current:    <0.0006 e-/pixel/sec @ -35ºC
  • CCD to Flange Distance:    17 mm (optical)
  • Lens Mounts:    C-Mount; optional Nikon F-Mount or Canon EOS
  • Available Shutters:    Sensor has an electronic shutter. Optional 25mm.
All Hyperion Cameras
  • Housing Dimensions:    6.75 x 4.0 x 3.35 (171.5 x 101.6 x 85.1mm)
  • Weight:    3.4 lbs. (1.5 kg)
  • Interface:    USB 2.0>
