ZWO ASI071MC Pro USB3.0 Cooled Color Astronomy Camera 256MB DDR3 Buffer [ZWO-ASI071MC-P]
Most famous sensor of Sony APS-C(1.8″) Diagonal 28.4mm 16M Pixel (4944×3284) Very low read noise: 2.3e @24db gain 3.3e @lowest gain 14Bit ADC: provide real 14bit Dynamic range Electronic shutter: no vibration problem with mechanical shutter ASI071MC Pro camera includes a 256MB DDR3 memory buffer to help improve data transfer reliability. Additionally, the use of a memory buffer minimizes amp-glow, which is caused by the slow transfer speeds when the camera is used with a USB 2.0 port.
ASI071MC Pro offers very good performance for Dark Current
the Dark Current of ASI071MC Pro is better controled than before with the help of DDR buffer and new improvment of hardware designastrophotography. Low read noise, high dynamic range.
We suppose the QE peak value is more than 50%.
ASI071 Pro includes unique tilt adapter. Say goodbye to tilt problems forever !
USB 3.0 Port: Provide 5Gb bandwidth to make it possible for ASI071MC Pro to run at 10 fps (14bit, normal mode) at full resolution(16Mega).
We recommend using a 12V/3-5A or more DC adapter for cooler power supply (2.1×5.5, center positive).
Using a battery with 9-15V is also suitable for the cooler power supply.
USB 2.0 HUB: Can connect with various accessories, including a filter wheel, guide camera or electronic focuser, allowing you to manage your cables better. There are two short 0.5m USB2.0 cables included with the ASI071 Pro. The hub is powered by the external power supply if you connect one.
New mechnical design and Anti-Dew Heater
ASI071MC Pro Camera completely upgrade anti-dew and mechnical body.
The diameter of the camera body is incresed to 86mm (ASI071MC-Cool is 78mm).
6 screws seal the chamber
This new structure seal the CMOS chamber better and no dew or frost happen on sensor anymore.
ASI071MC Pro has a two-stage TEC cooling system that allows deep cooling (35°C-40°C below ambient). You will need an external power supply to power the cooler.An AC-DC power adapter is not included in this package.
The anti-dew heater will heat the AR protect window to avoid any dew problems. The heat anti-dew heater power is around 3.6W and can be turn off in software to save power.
What’s in the box?
About ZWO ASI071MC Pro USB3.0 Cooled Color Astronomy Camera 256MB DDR3 Buffer [ZWO-ASI071MC-P]
ZWO Optical: ZWO ASI071MC Pro USB3.0 Cooled Color Astronomy Camera 256MB DDR3 Buffer APS-C size 4944X3284 @10fps Color USB3.0
- Most famous sensor of Sony
- APS-C(1.8″) Diagonal 28.4mm
- 16M Pixel (4944×3284)
- Very low read noise: 2.3e @24db gain 3.3e @lowest gain
- 14Bit ADC: provide real 14bit Dynamic range
- Electronic shutter: no vibration problem with mechanical shutter
What’s in the box?
Sensor: SONY IMX071 CMOS
Diagonal: 28.4mm
Resolution: 16Mega Pixels 4944X3284
Pixel Size: 4.78µm
Bayer Pattern: RGGB
Max FPS at full resolution :10FPS
Shutter:Rolling shutter
Exposure Range: 64µs-2000s
ROI: Supported
Read Noise: 2.3e @24db gain
QE peak: TBD
Full well: 46ke
ADC:14bit
DDRIII Buffer: 256MB
Interface: USB3.0/USB2.0
Adaptor: M42X0.75
Protect window:AR window
Dimensions: 86mm Diameter
Weight: 640g
Back Focus Distance: 17.5mm
Cooling: Regulated Two Stage TEC
Delta T: 35°C-40°C below ambient
Cooler Power consumption: 12V at 3A Max
Working Temperature: -5°C—45°C
Storage Temperature: -20°C—60°C
Working Relative Humidity: 20%—80%
Storage Relative Humidity: 20%—95%
Supported resolution
14Bit ADC
4944×3284 10fps
1920×1200 28fps
1280×1080 33fps
640×480 70fps
320×240 134fps
more resolutions are user defined
