ZWO ASI1600MM Pro Cooled Monochrome astronomy camera [ZWO-ASI1600MM-P]
ASI1600 Pro cameras, another giant leap in 1600 history!
ASI1600 Pro camera includes one 256MB DDR3 memory buffer to help data transfer more stable and no amp-glow issue which is caused by the slow speed data transfer during reading out under USB2.0 Port.
Astrophotography Performance
ASI1600 Pro offers very good performance for astrophotography. Low read noise, Low dark current, high dynamic range .
ASI1600 build in 12bit ADC but can provide 12.5 stops dynamic range which is even better than KAF8300 dew to its super low read noise.
Reliable Mechanical Structures
ASI1600 Pro using are 4 screws seal the chamber. This structure has been fully tested and is very stable.
Even under high humidity eviroment, ASI1600 Pro still works fine and won’t have dew problems.
What’s in the box?
ASI1600 Pro box includes all necessary cables, drivers, adapters, and manuals.
About ZWO ASI1600MM Pro Cooled Monochrome astronomy camera [ZWO-ASI1600MM-P]
ZWO Optical: ZWO ASI1600MM Pro USB3.0 Cooled Color Astronomy Camera 256MB DDR3 Buffer 4/3"size 4656X3520 @23fps Mono USB3.0
What’s in the box?
Camera technical details
- Sensor: 4/3″ CMOS
- Diagonal: 21.9mm
- Resolution: 16Mega Pixels 4656×3520
- Pixel Size: 3.8µm
- Max FPS at full resolution :23FPS
- Shutter: Rolling shutter
- Exposure Range: 32µs-2000s
- Read Noise: 1.2e @30db gain
- QE peak: 60%
- Full well: 20ke
- ADC:12bit
- DDRIII Buffer: 256MB
- Interface: USB3.0/USB2.0
- Adaptor: 2″ / 1.25″ / M42X0.75
- Protect window:AR window
- Dimensions: 78mm Diameter
- Weight: 410g
- Back Focus Distance: 6.5mm
- Cooling: Regulated Two Stage TEC
- Delta T: 40-45 below ambient
- Cooler Power consumption: 12V at 2A Max
- Working Temperature: -5°C—45°C
- Storage Temperature: -20°C—60°C
- Working Relative Humidity: 20%—80%
- Storage Relative Humidity: 20%—95%
Supported resolution
12Bit ADC
- 4656×3520 14.7fps
- 3840×2160 23.1fps
- 1920×1680 32.9fps
- 1280×960 47.1fps
- 640×480 80.4fps
- 320×240 124.4fps
10Bit ADC
- 4656×3520 23fps
- 3840×2160 36.2fps
- 1920×1680 57.7fps
- 1280×960 73.6fps
- 640×480 125.7fps
- 320×240 192.4fps
more resolutions are user defined
