Hyperion HPx285 Monochrome CCD Cooled Camera Sony ICX285AL monochrome sensor (no shutter) [FLI-HPX285]
Each component of the Hyperion camera is designed and manufactured for a long life in the most demanding conditions. Hyperion download speeds are fast yet maintain the 16-bit resolutionnecessary to produce high quality images. Hyperion cameras can cool to as much as 60°C below ambientwithout water assist. Simply set the Hyperion cooling where you want it and the camera will do the rest, quickly and without worries.
About Hyperion HPx285 Monochrome CCD Cooled Camera Sony ICX285AL monochrome sensor (no shutter) [FLI-HPX285]
Flight Lakes Instrumentation: Hyperion HPx285 Monochrome CCD Cooled Camera Sony ICX285AL monochrome sensor (no shutter) - 1360 x 1024 Imaging Array 6.45 μm Pixel Size
HPx285 Sensor Specs
- Sensor: Sony ICX285
- Pixels: 1360 x 1024
- Pixel Size: 6.45 μm
- Full Well Capacity: 18,000 e-
- Sensor Diagonal: 11.0 mm
- Video Size (inch): 0.7
- Anti Blooming: Yes
- Color Options: Monochrome
- CCD Type: Interline Transfer
- CCD Grades: Standard
HPx285 Performance
- Digitization Speed: 6 MHz
- Typical System Noise: 5 e- RMS @ 6 MHz
- Typical Maximum Cooling: 60ºC Below Ambient
- Typical Dark Current: <0.0003 e-/pixel/sec @ -40ºC
- CCD to Flange Distance: 17 mm (optical)
- Lens Mounts: C-Mount; Optional Nikon F-Mount or Canon EOS mount
- Available Shutters: Sensor has an electronic shutter. Optional 25mm
All Hyperion Cameras
- Housing Dimensions: 6.75 x 4.0 x 3.35 (171.5 x 101.6 x 85.1mm)
- Weight: 3.4 lbs. (1.5 kg)
- Interface: USB 2.0>
- Non linearity: <1%
- Remote Triggering: Standard
- Shutter MTBF: 1,000,000
