MicroLine ML8051 Color CCD Cooled Camera KAI-08051 (no shutter) [FLI-ML8051-C]
3.7 x 3.7 x 4.8 inches the MicroLine is a small camera with big camera capabilities. Each component of the MicroLine camera is designed and manufactured for a long life in the most demanding conditions.
About MicroLine ML8051 Color CCD Cooled Camera KAI-08051 (no shutter) [FLI-ML8051-C]
Flight Lakes Instrumentation: MicroLine ML8051 Color CCD Cooled Camera KAI-08051 (no shutter) - 3296 x 2472 Imaging Array 5.5 μm Pixel Size
ML8051 Sensor Specs
- Sensor: ON Semi KAI-08051
- Pixels: 3296 x 2472
- Pixel Size: 5.5 μm
- Full Well Capacity: 20,000 e-
- Sensor Diagonal: 22.5 mm
- Video Size (inch): 1.41
- Anti Blooming: 300x
- Color Options: Monochrome or Color
- CCD Type: Interline Transfer
- CCD Grades: Standard
ML8051 Performance
- Digitization Speed: 1.5 MHz & 12 MHz (optional two channels @ 10 MHz each)
- Typical System Noise: 3.5e- RMS @ 1.5 MHz; 6e- RMS @ 12 MHz
- Typical Maximum Cooling: 55ºC Below Ambient
- Typical Dark Current: <0.001 electrons/pixel/sec @ -30ºC
- Non linearity: <1%
- Lens Mounts: Optional Micro 4/3, Nikon F-Mount or Canon EOS mount
- Available Shutters: Sensor has electronic shutter. Optional 45 mm
All MicroLine Cameras
- Housing Dimensions: 3.70 x 3.70 x 4.77 (9.3 X 9.3 X 12.1 cm)
- Focal Plane to Faceplate: 15.7 mm (optical)
- Weight: 2.8 lbs
- Interface: USB 2.0
- Remote Triggering: Standard
- Shutter MTBF: 1,000,000
