MicroLine ML8050 Color CCD Cooled Camera KAI-08050 (no shutter) [FLI-ML8050-C]
FLI-ML8050-C
$5,169.85 USD
Flight Lakes Instrumentation: MicroLine ML8050 Color CCD Cooled Camera KAI-08050 (no shutter)  - 3296 x 2472 Imaging Array 5.5 μm Pixel Size
3.7 x 3.7 x 4.8 inches the MicroLine is a small camera with big camera capabilities. Each component of the MicroLine camera is designed and manufactured for a long life in the most demanding conditions.
About MicroLine ML8050 Color CCD Cooled Camera KAI-08050 (no shutter) [FLI-ML8050-C]
ML8050 Sensor Specs
  • Sensor:    ON Semi KAI-08050
  • Pixels:    3296 x 2472
  • Pixel Size:    5.5 μm
  • Sensor Diagonal:    22.5 mm
  • Video Size (inch):    1.41
  • Anti Blooming:    300x
  • CCD Grades:    Standard
ML8050 Performance
  • Digitization Speed:    1.5 MHz & 12 MHz (optional two channels @ 10 MHz each)
  • Typical System Noise:    8e- RMS @ 1.5 MHz; 10e- RMS @ 12 MHz
  • Typical Dark Current:    <0.001 electrons/pixel/sec @ -35ºC
  • Lens Mounts:    Optional Micro 4/3, Nikon F-Mount or Canon EOS mount
  • Available Shutters:    Sensor has electronic shutter. Optional 45 mm
All MicroLine Cameras
  • Housing Dimensions:    3.70 x 3.70 x 4.77 (9.3 X 9.3 X 12.1 cm)
  • Weight:    2.8 lbs
  • Interface:    USB 2.0
