MicroLine ML4070 Monochrome CCD Cooled Camera KAI-04070 (no shutter) [FLI-ML4070]
FLI-ML4070
$5,684.85 USD
Flight Lakes Instrumentation: MicroLine ML4070 Monochrome CCD Cooled Camera KAI-04070 (no shutter)  - 2048 x 2048 Imaging Array 7.4 μm Pixel Size
3.7 x 3.7 x 4.8 inches the MicroLine is a small camera with big camera capabilities. Each component of the MicroLine camera is designed and manufactured for a long life in the most demanding conditions.
About MicroLine ML4070 Monochrome CCD Cooled Camera KAI-04070 (no shutter) [FLI-ML4070]
ML4070 Sensor Specs
  • Sensor:    ON Semi KAI-04070
  • Pixels:    2048 x 2048
  • Pixel Size:    7.4 μm
  • Full Well Capacity:    44,000 e-
  • Sensor Diagonal:    21.4
  • Video Size (inch):    1.3
  • Anti Blooming:    1000x
  • CCD Grades:    Standard
ML4070 Performance
  • Digitization Speed:    4 MHz and 12 MHz (optional 2 channels at 12 MHz each)
  • Typical System Noise:    8 e- RMS @ 4 MHz; 11 e- RMS at 12 MHz
  • Typical Dark Current:    <0.001 e-/pixel/sec @ -35ºC
  • Lens Mounts:    Optional Micro 4/3, Nikon F-Mount or Canon EOS mount
  • Available Shutters:    Sensor has electronic shutter. Optional 25 or 45 mm
All MicroLine Cameras
  • Weight:    2.8 lbs
  • Interface:    USB 2.0
